    Jan 2003
    I'm surprised I couldn't find the answer searching but is there any way to burn disk-at-once using VCDeasy's Cdrdao driver? I haven't been able to get adaptecs ASPI drivers to work so I had to move neros win32aspi.dll to the cdrdao folder in order for anything to burn. I don't see any options at all for disk-at-once burning anywhere in the GUI. I know you can with Nero, but I like to burn VCDs with no PBC which is why I am using VCDeasy.
  2. Anonymous
    Guest
    I think it only burn "disk-at-once", no?
    MO, US
    That's right, cdrdao can only burn in DAO mode. That's what the "dao" in "cdrdao" represents, it's a tool specifically for burning DAO discs.
    Jan 2003
    Maybe I misuderstand the phrase "Disk-at-once" What I mean is, is there a way to have VCDeasy write directly to the disk instead of writing an image first? When I burn a VCD with VCDeasy, it always writes an image to my hard disk first, which takes time, then burns it to the CDR. If I use Nero, it doesn't write it to my hard disk first, it just writes it directly to the CDR, which is what I want VCDeasy to do.
  5. Anonymous
    Guest
    No, unfortunatly there is no way of burning with VCDEASY+CDRDAO without making an image first...
    Jan 2003
    Hmmm. Can you do it using adaptec aspi?
