Soundcard used Sb128 pci..Line In Input from a scart adapter (left out/right out). Video from composite. Sound is super hissy!
What is the cause ? tape ? vcr ? bad cable's ? bad soundcard ?
I get way less hiss if I record my voice with the microphone in the mic slot :S
My tv-card is PCTV Rave.
Otherwise I'm happy with the capture results..but the sound..it's not acceptable.
I'm not sure what you mean by hiss, but if it's what I think you mean, the most likely cause is from the VCR. The action of the tape dragging across the audio head(s) can cause a hiss, even when there's recorded silence on the tape. My first suggestion would be to clean the heads in the VCR. The audio head(s) are seperate from the video head so even if the picture looks clean, the audio can be dirty. If that doesn't help, (or help enough), you can extract the audio, use CoolEdit to remove the hiss, then re-mux.
If the problem is more of a hum then the source could be from any of the sources you mentioned, or none of them. Try repositioning your equipment (if possible) to get the VCR further away from the computer, or try using cables with gold tips. If you have a UPS for the computer, try moving that as far away from the computer and VCR and cables as you can. Try your sound card in a different slot. If the video card is PCI, try moving that to a different slot.
captured audio and video are desynced
By muffinman123 in forum Capturing and VCRReplies: 1Last Post: 5th Sep 2011, 09:03 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 05:54 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 12:39 -
Audio problems with captured video on computer
By seeviper in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2007, 10:06 -
audio becomes a hiss
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Jul 2007, 00:03
