Now i do a movie only backup,this way when a movie needs reencoding i cna use a higher bitrate to fill the disc.
Now im readin that IC7 is the only all in one program that comes close to CCE on quality(i use CCE).Now from what ive been reading IC7 cant do a movie only backup(movie,5.1 audio and chapter skip,no menu).Now i might get IC7 for those smaller dvd's i.e about 5gb as i will do a full backup of a movie thats about 5gb if i can still maintain a good bitrate.
Now i would like abit of info on IC7 please as ive read theres some bugs like it dont use the full disc space of a dvdr. True ?? y or n?
And is there any other bugs in it.
Thanks.
all you need to know about the pitfalls of using IC is HERE in the guide
yes it's true it undersizes, but if you do a few simple checks 1st it is easily overcome in most cases
it's the smaller 2.35:1 movies that cause problems for IC due to the black bar content and normally anything smaller than 5Gb will not work and it will undersize even if you set it to 99.90%
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Need some general info...
By bjgdal in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Jan 2009, 21:29 -
Need info on walkm8
By Shaorin in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2007, 01:05 -
info on nashi
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2007, 04:22 -
HD DVD info
By skaterboii in forum Newbie / General discussionsReplies: 3Last Post: 27th May 2007, 04:43
