I can't seem to capture audio from VHS using Dazzle DC80.
Connection works from VCR to TV. I can capture audio from DV-Cam to DC80. Only thing that may be at question is vcr is not stereo and I have a Y adapter for L/R channels into VCR. Any help would be great.
ZPhreak
Try connecting the audio cable fron your SCART / VHS into a amplifier such as a portable "boombox" or similar...
that worked good for me... =)
/haiko -
Can't you bypass the Dazzle altogether, and just run the audio to the soundcard?
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Would there be a way to smooth out audio dips in a vhs capture?
By yoda313 in forum AudioReplies: 27Last Post: 10th Jan 2011, 16:46 -
How can I capture VHS Audio with best quality possible?
By faramith in forum AudioReplies: 5Last Post: 13th Feb 2009, 06:09 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 7th Feb 2008, 23:27 -
Audio Disappears After VHS Capture
By drjax in forum Capturing and VCRReplies: 0Last Post: 11th May 2007, 02:48
