Hello!
I got a PCTV Deluxe four days ago and I have no problems so far (Strange eh?).
I have no dvd burner so the only thing I burn so far are VCD/SVCDs. The problem is that when I capture straight to the apropriate resolutions, the video looks bad, the low resolution is obvious even when I watch the videos in my TV set. I can almost count the pixels!
Am I doing something wrong? Is it better to use another capture program than Vision? Or the only way to go is to capture at DVD quality and then re-encode?
Please note that I use so far USB 1 connection, but I don't think this is the problem...
Sorry, I don't have experience with VCD or SVCD, but did you try to play it on TV ? Maybe it will not look that bad. On computer due high resolution, you see much more than on TV
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I donīt have experience it USB Capture Cards, but i have a Pinnacle PCTV, i have tried o lots of software it bad results, like you I can almost count the pixels!
Recentely i have discover WinDVD Recorder and now i have good quality it my videos.
Download the trial version now, it is the solution for you(works it USB Cards?)
Good settings in MPEG2 + 1800bitrate. -
Difference is that this (USB) box is hardware mpeg encoder with Broadcom Kfir-II (BCM7040KQL) chip. I believ it is manufactured by Emuzed.com . So I don't believe that it is fair to compare it with captures that are converted to mpeg by sofware. Well... that still doesn't explain bad experience by unforgiven.
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41 -
Pinnacle PCTV HD Ultimate Stick
By bigjimmpls in forum Capturing and VCRReplies: 19Last Post: 28th Dec 2007, 15:40 -
Pinnacle PCTV USB 2 - Vista
By hellybelly in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 04:20
