i have downloaded films but thay r too big to put on disc how do i split the film to fit i need a easy prog as im new to all this i have tmpge but dont know how to use it properly any help is very needed
Deoends on what you want to watch the movie on....do you want to be able to watch it on your home DVD player?...or do you just want to be able to watch it on your PC?
If you just want to watch it on your PC then you can just cut the movie in half with Virtualdub:
https://www.videohelp.com/virtualdubedit.htm
If you want to watch it in your home DVD player then you will need to encode it to either VCD or SVCD...(SVCD is best if it will play on your player)...TMPGenc is the easiest program to do this and gives nice results, and is nowhere near as complicated as it looks at first...check out the beginners guide:
https://www.videohelp.com/tmpgenc.htm
or for SVCD:
https://www.videohelp.com/tmpgencsvcd.htm
Don't give up if it looks complicated....keep trying..its well worth it in the end.
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
Help with splitting
By stinger161 in forum EditingReplies: 1Last Post: 29th Oct 2009, 18:58 -
The Independent Film Channel - efficient film challenge - cash prizes
By minidv2dvd in forum Latest Video NewsReplies: 1Last Post: 23rd Oct 2009, 10:44 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
My DVD Film backups are 'freezing up' near end of Film
By Artom in forum Newbie / General discussionsReplies: 5Last Post: 18th Jun 2007, 04:01
