My DVD-Rom that I use for ripping (Hitachi gd-7500) has started to give me an error when I trie to rip ANY DVD using DVD Decrypter 3.1.5.0.
The error looks like this:
I/O Error!
Device: [0:1:0] HITACHI DVD-ROM GD-7500 X008(K
ScsiStatus: 0x02
Interpretation: Check Condition
CDB: A4 00 00 00 01 3D 00 00 00 0C 04 00
Interpretation: Report Key - Title Key (0)
Sense Area: 70 00 05 00 00 00 00 0A 00 00 00 00 2C 00 00 00 00 00
Interpretation: Command Sequence Error
When I try to ripp the same DVD in my Sony DRU-500AX I get no errors (but it takes forever since it only can rip at 2x).
I then thougth it might be the DVDs that where strange so I tried to ripp an old DVD that I have ripped with the Hitachi before and I got the same exact error. Does anyone know what is going on? Is my Hitachi DVD-ROM dying?(It can still play the same DVDs that gives error in DVD Decrypter using PowerDVD
I have tried to ripp it with Smartripper also and that works just fine, so it should not be the Hitachi that is doing this , should it?
Might it be a bug in DVD Decrypter that does this?
Actually when I think back the error started after I used the Sony to ripp a movie and then went back to the Hitachi to rip. Could it be some kind of faulty device handeling in DVD Decrypter that causes this?
Anyone have any idears?
By the way my computer setup is as follows:
Dual PIII 1,13GHz Taulatin
Tyan Tiger 230T MB
128MB PC-133 Ram + 512Mb PC-133 Ram
MSI Geforce-4 ti4200 128Mb DDR
IBM 30GB HD on Promise Controlle IDE0:master
IBM 60GB HD on Promise Controlle IDE0lave
WD 80GB HD on Promise Controlle IDE1:master
WD 1200GB HD on Promise Controlle IDE1lave
Plextor 12/10/32A on MB IDE0:master
Hitachi GD-7500 on MB IDE0lave
Sony DRU-500AX on MB IDE1:master
I was having the same problem with my Hitachi GD-7500 and Decrypter 315,but it was working with my Sony and Lite-On DVD-Rom's. I changed back to Decrypter 313 on the Hitachi and that solved the problem. Appears to be a compatibilty between the Hitachi GD-7500 and Decrypter 315.
Enchanted error (DVD Decrypter)
By rickygg in forum DVD RippingReplies: 1Last Post: 4th Apr 2008, 09:39 -
DVD Decrypter error
By turbochargedRS in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 19:08 -
i/o error in DVD Decrypter
By msdker in forum Newbie / General discussionsReplies: 18Last Post: 20th Dec 2007, 22:03 -
DVD Decrypter error
By tRAVALO in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Aug 2007, 11:10 -
Error with DVD Decrypter...
By hiimbored in forum DVD RippingReplies: 29Last Post: 4th May 2007, 20:37
