I have backed up quite a few dvd's with the decryptor/dvd2one/prassi method ( movie only ), and have had a very good sucess rate. I just watched my backup of Scorpion King, the sound seemed out of sync in places. Now I don't have the original lying around to check ( it's at Blockbusters), so not sure if it started this way.
Anyone had problems like this before?
cheers
Kevlar
There are always posts about problems with audio synching probably 10% of all posts I have seen are about that.
I would be very suprised if the Scorpion King was released with an inherent audio problem, and if it had it would of been recalled.
I would check your method as that must be where the problem is occurring. -
Makes sense!. But I can't see how I could screw the sound up, all I do is rip movie in decryptor, use DVD2ONE to either compress to correct size, or just to create compatible .ifo's/.bups, then write with Prassi primo. Is there an issue with DVD2ONE? or maybe Decrypter mucks up when ripping movie only, or stream ripping?
Puzzled
Kevlar
Sound out of sync in Avidemux
By Lambert in forum EditingReplies: 21Last Post: 19th May 2010, 00:59 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
Slideshow with sound in sync
By tin2tin in forum User guidesReplies: 0Last Post: 18th Jun 2008, 04:07 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 09:31 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 20:11
