Hi,
I'd like to buy a VCD Recorder, for the purpose of easily transfering VHS to VCD (which I can play on the move). I live in the UK, and would like to know where I can buy a VCD Recorder, as cheaply as possible. It only has to record VCD, preferably to CD-RW, with a facility to blank the disk. It should also be easy to use (press record button and it begins to record from external VCR).
How much can I expect to pay for this unit, and where can I get it from.
Thanks in advance,
Matt
Never use this but this turns out to be my final choice when I was looking for one long ago (although I have decided not to get any at all).
http://www.edgereview.com/ataglance.cfm?category=Video&ID=111
Just a reference. Don't take it too seriously. -
Don't buy a VCD recorder, pay the extra and buy a standalone DVD recorder. VCD is dead. And you will get no support for a VCD recorder.
http://www.lik-sang.com/info.php?category=124&products_id=2580&
2nd generation of Video Disc Recorder, records even Macrovision protected material
Input from various sources-- Camcorder, TV, DVD, VCR, CD, VCD and SVCD player
CD-R and CD-RW disc Recordable
Selectable recording format--VCD (250 lines), SVCD (350 lines) or CD format
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 19:23 -
Any recomendations on cheap Portable mp4 recorder with A/V input?
By leffe in forum Capturing and VCRReplies: 3Last Post: 1st Apr 2008, 23:27 -
Looking for a Stand alone, cheap, DVD recorder, timecode on screen.
By AtomX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 16:10 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19 -
decent dvd recorder for.... cheap
By zamac_man in forum Capturing and VCRReplies: 4Last Post: 22nd Jun 2007, 13:00
