Results 1 to 9 of 9
  1. Everytime i convert a 25fps file to divx (or anyother codec infact) the sound goes off sync. I have to change the frame rate to match it. Why do i have to have 24.971 fps. It also goes off sync when i capture. Last week it was perfect. What has happened??
  2. you need to state what you are using to encode and your settings before anyone can attempt to answer. what is the source info?
  3. In virtualdub. All the settings do the same thing. I have to change the frame rate to get sync
  4. ANY file that i save in vdub no matter the codecs (a or v) goes out of sync? Its getting me down
  5. 154 views but no one answers. dont anyone know?
  6. Vdub is usually very good when converting. Have you checked the audio settings i.e there is no preset delay left in?
  7. I am starting too see more discussions about which product is better in these forums than help.
    Like tompearson said, check to see if there is any delay setting in the audio. That is usually the cause of something like that.
