I've got an avi file that (GSpot) says it's sound uses the AC3 codec... does this mean I can encode to DVD with 5.1 sound? If YES, how and with what software?
Cellarboy
I'm not sure about the 5.1 but you can get ac3 sound by using headac3he.
Yes you can.Originally Posted by cellarboy
Seperate the audio out from the video, using virtualdub, audio, direct stream copy, save as wav.
rename the wav file to file.ac3
Check and fix any errors in this file with ac3fix.exe (available in the tools section). You will now have file2.ac3.
Convert your video only to mpeg-2 with your favourite encoder.
Now author using a proggy that will accept ac3 streams. I know SpruceUp and Ulead DVD WS will do this, and I know there are others.
Hope this helps
How to burn avi file with true 5.1 ac3 sound on dvd?
By namesake in forum Video ConversionReplies: 17Last Post: 20th Mar 2009, 11:49 -
mencoder, convert mkv to avi + ac3. sound issues
By clavain in forum Video ConversionReplies: 1Last Post: 29th Jan 2008, 18:02 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35 -
AVI with AC3 - No Sound
By Degradation in forum AudioReplies: 0Last Post: 19th Dec 2007, 17:28 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 15:06
