I'm using Premiere 6 and TMPGEnc and plan to9 use the avisynth plug-in. I've read somewhere about single pass vs multi pass encoding and would like to know more about this. They said multi pass encoding is far better and gives a better, higher quality VCD.
Can you give me some insight?
Allen
visit my China Railways page at;
http://www.azagel.com/crail.html
MIDI music on my site also. Have a nice day. -
Multipass encoding only makes sense for SVCD or XVCD where the bitrate is variable (VBR). VCD is a constant 1150 kbps bitrate, and so multiple passes do nothing for it. Multiple passes are used to allocate more bits to the more complex scenes and fewer bits to simpler scenes.
Thank you.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46 -
AutoGK Filesize in Single Pass Mode
By Arlo in forum DVD RippingReplies: 3Last Post: 7th Jan 2009, 17:21
