made up a dvd of tv eps.
it works on the dvd player in my pc
but not in my stand alone dvd player
why is this
i know my player acepts copied dvd and on the media im using?
can anyone give me any advice on this and also
on copying vcd to dvd?
used ulead moviefactory 2 for this
could you explain how you are making the vcds?
vcd to dvd www.dvdrhelp.com/vcddvdr -
Is your dvd player multi region ?, are you creating vcd's, svcd's, xvcd's ?.
Some more info please. -
i am using this guide
i have 5 eps of a tv series i want to put onto dvd
i have converted them to mpeg 1
with tmpge
i then use moviefactory to burn to dvd
i had a few probels to start of with when using it
however i finaly managed to created a dvd
which as i said workd on the pc but not on the standalone dvd player
i ahve a dansi 852 which has been hacked.
i used bulkpag media which does work on this dvd player
as i have made up backed up dvds before.
looking at the guide the one thing i did notice is the frame rate
for each mpeg was less than 29.975 it was about 25.
should i just convert the mpeg to mpeg 2? -
I have found that some players don't like 352x240 mpeg1...... My Pioneer 333 is one of them. Take the same DVD, put it in my JVC or Panasonic, and it's fine. Plays on my PC as well.
If I do 352x240 mpeg2, then it works in the Pioneer.... wierd.
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 22:43 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
Rip a strange work made DVD
By jntaylor63 in forum DVD RippingReplies: 5Last Post: 22nd May 2009, 05:45 -
DVD with a home made video of a wedding can not get it work on dvd player
By kyrieanddave in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 11:03 -
Looking for a blu ray player that can be made multi region for standard dvd
By stoksyXL in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Feb 2008, 09:53
