I'm having problems burning some avi files to dvd. I downloaded several movies in avi format (Matrix for example). I tried converting them to mpeg using TMPGEnc. Both the downloaded avi and the newly encoded files do not play video or audio. Any help???
I'd suggest concentrating on getting the AVI to work first. If the AVI doesn't work and then you re-encode it chances are the MPEG wont.
Check things like the codecs you've got installed. Repost with any error messages Mediaplayer might bring up in the bottom left hand corner. Try searching through the forums once you find out where the problem lies.
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 10:36 -
help burning AVI file onto DVD
By dunce in forum Authoring (DVD)Replies: 31Last Post: 10th Feb 2010, 20:40 -
Burning a AVI file to dvd
By tim_ver in forum Newbie / General discussionsReplies: 14Last Post: 7th Dec 2008, 08:05 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 07:40 -
AVI to DVD Burning
By DVDHelpPlease in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 00:38
