I've got something new for you guys! I downloaded a movie
and when I checked the file information it states 48000Hz 1
channel (mono).
What in the World can I do with 1 channel mono audio? Is
there a way to convert it to some kind of dual channel audio?
I've never experienced any movie with mono audio.
Any ideas?
Turk
Why doesn't this work?
Not a James Bond movie by any chance is it?
Load it in virtualdub, then select
audio->full processing,
audio->conversion, select stereo (will be dual channel mono in reality)
audio->compression (None) (or whatever you prefer)
File-save wave
You now have a dual mono (stereo) version of the soundtrack to do with as you please. -
Bugster, thanks for the reply. Your suggestion
makes perfect sense. I'll definitely give it a try.
TurkWhy doesn't this work?
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 13:14 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Best way to convert DVD-r w/ 1 channel audio to mono?
By progrocktv in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2009, 15:57 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45 -
how to: add 2 mono tracks = 2 channel wave?
By spiritgumm in forum AudioReplies: 4Last Post: 7th Sep 2007, 16:52
