  1. How do I convert a single downloaded .vob clip to a avi or mpg?
    Then edit that clip, trim parts that I don't want out?
  2. open it in DVD2AVI, then save project. Framserve to VirtualDub. Save as AVI or whatever.
  3. where can i get that?
  4. click the tools section on the left for software.
    Don't knock on deaths door, ring the doorbell and run, death hates that!
  5. The most direct way is to use VobEdit or Xmuxer to convert your .vobs to a single mpeg2. You can do whatever you wish with the mpeg2.
    You can see the following link for how to use VobEdit:
    https://www.videohelp.com/forum/userguides/120021.php
