Hi
Ineed to interconnect my DVD´s progressive-sacn component-video output (3 RCA plugs) to my projector´s VGA input (15 pin DB connector).
Can any body offer a pinout diagram , so I can assemble the cable ?
From the projector´s user´s manual I know that this is the only way to connect the DVD (progressive-scan) to the projector .
Here in Brazil, this cable is not available on the local market.
Abraham
AFAIK, this isn't just a cable you need, but a converter which you can find here:
http://www.svideo.com/video2vga.html
(NOTE: this is not a reccomendation, just one such device I found via google, there are other manufacturers, this is just an example) -
I believe it is just a cable , because the projector´s user´s manual says so; there are such cables on the US market , but they are expensive and
for me it is complicated (and outrageous) to import the cable to Brazil.
Component to VGA
By aznSzeto in forum Newbie / General discussionsReplies: 4Last Post: 23rd Feb 2012, 22:31 -
Intel GMA HD/Core i3 - VGA has TV-out/S-video-out/component-video-out?
By Morality124 in forum Media Center PC / MediaCentersReplies: 5Last Post: 9th Jan 2011, 00:44 -
How do I connect my Laptop (VGA) to my TV (S-Video or RCA or component)
By setenay kabardey in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2010, 14:08 -
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 21:48 -
Should I use Component or VGA for HDTV?
By jdmbo1 in forum Media Center PC / MediaCentersReplies: 16Last Post: 22nd Sep 2007, 21:37
