how do i know what to use PAL or NTSC?
You aren't making this easy to answer.
Where are you? (country/continent wise)
Depends as to what your region's broadcasting standard is:
Eg. USA = NTSC. Australia/Europe = PAL.
Check what your TV is. When you install any Ulead programs for the first time they ask what country you are in. Depending upon your answer it will default your software to it.
Having said all that, most modern players and TV's handle both anyway, but check what your TV is.
If this is DV stuff you are editing, check the camera you are using to capture.
If it is a DVD, check the cover - it will tell you.
Have a look at think link:
http://www.christiananswers.net/catalog/videostandards.html
(Holy Cow - LOL - That web link wasn't supposed to be a bible-bash, it was the first useful link google returned. Definitely not preaching here. Cracks me up - a devout atheist sending a Christian link )The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
