well i am a newbie and didnt know there were different kinds of dvd's for different players, therefore i have a dvd-r player for main tv and dvd+r on new pc...so i record in dvd+r and it wont work in my dvd player at main tv which is dvd-r. Is there anything i can do to get them compatibale without buying a new dvd recorder or player...
does anyone know if dvd-r will play vcd's on my dvd-r player at main tv..its a toshiba sd1700...
i have been messing with this mess for a month now...please help thanks in advance
your dvd player is not a "dvd-r" - its dvd player.
info here : https://www.videohelp.com/dvdplayers.php?DVDnameid=476&Search=Search&#comments
it says it will play both dvd-r and dvd+r disks -
Correct, try different media, or try a different burn process. There is some reason other then + media why its not playing.
Whatever tools you are using, just make an ISO file & burn with Nero while checking the DVD-ROM booktype under the burn tab. This works everytime.
I would recommend for you to check out +RW media instead of +R. I have a Sony NS700P standalone DVD player and it does not read +R media, but It reads +RW media perfectly.
Newbie Question - DVD+R versus DVD-R
By bobelk99 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2011, 18:05 -
DVD - R versus DVD + R for DVD movies ( Is one better than the other ?? )
By beammeup in forum DVD RippingReplies: 17Last Post: 25th Sep 2010, 07:20 -
TV tuner versus DVD recorder?
By Lupo in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2009, 00:15 -
Why do HD dvd play chopping using computer versus smooth on blueray player
By CX7 in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 17:23 -
Market Share BlueRay\HD Versus SD DVD
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2008, 17:59
