i need to convert from avi to ifo and save to hard drive
The ifo file is just a small part of the DVD file structure. To generate it, you would normally use a DVD authoring software package. You can also use a newer version of IFOEdit to create an IFO file, however, it will not accept AVI as an input.
You need to convert your AVI to MPEG-2 using any encoder that handles MPEG-2 (CCE, TMPGenc, MainConcept, Etc). The output from the encoder can then be dropped into your authoring software.
Start in the HOW TO section. Specifically in the GUIDES section, converting DivX/XviD To DVD, or AVI to DVD.Impossible to see the future is. The Dark Side clouds everything...
alternative to autogk to convert ifo to avi
By lordrt in forum DVD RippingReplies: 2Last Post: 12th Nov 2010, 07:51 -
How to convert .BUP and .IFO to AIFF, AU, FLAC, M4A, OGG Vorbis or WAV
By MLK3329 in forum Video ConversionReplies: 6Last Post: 5th Oct 2010, 21:13 -
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 12:14 -
How to merge/combine and/or convert VOB, BUP, and IFO into one file?
By gordes04 in forum Video ConversionReplies: 3Last Post: 11th Apr 2010, 20:39 -
How to convert IFO/ Vob to mpeg (sony DVD camcorder)
By Guthix in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2007, 19:05
