Hi, I'm looking for help or a guide as to how I can insert my own jpeg screen or short video at the beginning of a dvd I burn. Presume I'm starting with a fully and legally ripped movie on my hard drive (using one of the dvd decrypter methods). I've got (though haven't necessarily used) all of the following:
dvdxcopy
dvd decrypter
dvd2one
dvdshrink
pinnacle instantcopy
IFOedit
VOBedit
daemon tools
Thanks for any advice
the only idea i have, is to make a mpeg2 movie with your jpeg files (using premiere for exemple) so you'll have an .m2v file which is dvd compilant and then demux the ripped movie and re-author it adding as first track the .m2v file.
I use VCDeasy to convert my JPEGs to an mpeg format.
you could try that -
HI
I also use VCDEasy and its great! Just take a picture and "convert" it to mpeg. Then use it as startpicture ore for "change CD"-Advise.
JUst look for an guide, there every step is explained.
Good luck
DiverWelcome - to the real world
Inserting photos in a music video with movie maker
By Olustee bus in forum ComputerReplies: 0Last Post: 5th Sep 2011, 12:30 -
ffmpegX only encodes warning at beginning of movie
By kgplumb in forum ffmpegX general discussionReplies: 2Last Post: 29th Aug 2010, 09:07 -
Inserting blank frames with logos before movie start
By multiplex in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2008, 21:30 -
Software suggestions for video clip or motion menu at the beginning of DVD?
By hitman3000 in forum Authoring (DVD)Replies: 2Last Post: 14th Mar 2008, 20:30 -
Inserting subtitles into a movie
By aussiekev in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 07:13
