I recorded from a vcr using my ATI card. After recoding I now have files with .vcr file extension. I would like to change the file extension to mpg, avi or mp2 file extension. The .vcr file extension is not compatible with Pinnacle Studio 8. I will be using Pinnacle Studio 8 to make to make home video films, and then burn them to DVD. Is this possible?
Why did you record in VCR format to begin with ?
The AIW allows you to capture to MPEG1/2 as well.
If you launch the Media Library, you can convert from VCR to MPEG2, but it's better to capture to the DVD-compatible presets directly from ATI MMC.
J4F file extension
By mariestalet in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2009, 04:53 -
New File Extension To Convert
By EDS001 in forum Video ConversionReplies: 6Last Post: 20th Mar 2009, 17:59 -
Converting to new file extension
By Nitro89 in forum Video ConversionReplies: 11Last Post: 17th Apr 2008, 13:42 -
What would cause the file extension icon to come up empty?
By Captain Satellite in forum ComputerReplies: 22Last Post: 14th Nov 2007, 20:17 -
wht is the .ff file extension
By modular1 in forum ffmpegX general discussionReplies: 3Last Post: 9th Oct 2007, 06:05
