Downloaded "The Two Towers" screener on a pair of avi files compressed with x-vid. Used MainConcept Encoder to convert them to mpgs. Used MovieFactory2 to convert the mpgs to vobs. Used DVD2One1.1.3 to slightly compress each vobset to 90% of original size(otherwise would be 9.3Gb,too large for the 3 appz in question to process,as I discovered). Used Vobedit to merge them to 8.4Gb and IFOedit to write the new IFO files. Then I started my experiment; to burn the 8.4Gb file onto a 4.7Gb DVD-R using each program to see which result I would keep. InstantCopy7 yielded a 3.8Gb file that had definite noticable tiny "blocks". DVD2One had none of that,but seemed to have an occasional irritating "fog" across the screen. DVD95Copy had a very slight degree of the "tiny blocks", but no "fog". I kept the DVD95Copy disk. My conclusion: Uninstalled InstantCopy7,DVD2One had the fastest speed and selectable filesize, but DVD95Copy has the best quality.
Closed Thread
Please, I said Please, stop it with all these comparisions,
convert them anyway you like, and try to help everyone
troubleshoot their problems, cant compare these three
without leaving scores of others out, like shrink and the
rest, especially with a "screener" you illegally downloaded....
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
I use all of the nice programs we have available with the exception of IC. I still have IC on the computer but just never use it (too darn slow).
