Hi,
I recently copy vcd in my harddisk & I convert that .dat files into mpeg by vcdgear 2.0. Now using winoncd 3.7 when I trying to make vcd or when i drag this mpeg file in winoncd message box appear "not a mpeg file". After that I also run this .dat file in "vcdcutter" and grab as a mpeg file but result is same.
Please help me how can i make vcd of that .dat files.
thankyou.
If all you are interested in is copying the VCD (and you still of the original with you), you don't need to copy the dat file over to your HDD at all.
Just use the CD copy function with your favourite CD burner proggy.
Regards.
Michael Tam
w: Morsels of Evidence
Error message when trying to encode one file using AVStoDVD Program
By spritely in forum Video ConversionReplies: 3Last Post: 25th May 2011, 12:52 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
AVI2DVD file access denied message
By playaa in forum Video ConversionReplies: 3Last Post: 4th Aug 2008, 19:15
