Strange one this :
I'm using a registered version of the encoder, but it refuses to recognise any MP3 audio streams in any of the AVI films I want to convert to put onto DVD
I could use another converter I have, but this one does everything I'm looking for, and it doesn't fall over if it can't do the conversion in a batch, unlike a couple others I've used before
It recognises MPEG Layer-2 streams, but any AVI that has a MPEG layer-3 stream, it insists there is no audio, weird thing is they all play via any of the players I use
I've uninstalled, and reinstalled the codec, blocked that codec and installed another MPEG codec, removed any MPEG codec that may be causing conflicts, still the same
Now, if the players can play the films, and I disabled the MP3 codec to try this, they were silent, re-enable the codec, you have sound again
Why can't MainConcept see the codec, instead of winging there is no audio stream
The players I've tried and use are :
IrfanView, MS MediaPlayer and The Core Media Player. They all play anything I throw at them, with no complaints
I'm guessing its a codec fault somewhere, and as I've just spent a week reinstalling, and setting back up my whole system after reinstalling WinXP Pro to a fresh format, I know the system is clean with no conflicts
Thanks for any help
Try using Virtual Dub to save the audio part as a wav file. Main Concept will accept that. I would also save the video portion of the avi without the audio using Vdub. Load the video only portion and the audio only wav file into Main Concept.
go to options -> import modules ...
try disable avi (so directshow only decodes the avi instead) ..
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
DVDFab won't recognise DVD
By audax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 00:16 -
My PC will not recognise my MP3- It was fine for 8 months??!
By jenniewb in forum ComputerReplies: 8Last Post: 28th Dec 2008, 11:30 -
Sony DVD RW DW-D18a - Won't recognise CD audio/games/CDRs
By knightime in forum DVD & Blu-ray WritersReplies: 3Last Post: 27th Jun 2008, 05:08 -
OS won't recognise harddrives
By mysts in forum ComputerReplies: 6Last Post: 9th Mar 2008, 13:57
