Hi,
I have this problem with this vobfile.
When I use mpg2cut I have a Vob file that can't be used by vobedit or a proggie like that.
I have this dvd from wich I only want to keep certain parts of the vob.
When I cut the first vob there is no problem and this one can be split into a vid and audio file zo that I can author it.
But vob 3 has no header information after the cutting so it can't be demuxed with vobedit.
How can I solve this problem there must be a way to cut up a vob and then demux and re-author it.
Hi,
The problem is solved for me
I use the new TMPGenc DVD author program and with that I can cut up the vob and make a simple dvd. Then I have the choice leave it like that or use dvdlab to add more chapters cool looking menu etc...
I think this is already possible in TMPGenc but I just have used it for the first time and I realy like DVDLAB so I will look further into the possibilities of this TMPGenc dvd author software and making chapters and menu.
Great to finnaly have a piece of software that can cut and edit files and makes a whole new dvd standard file so that you can use any programm
you want with it. Two thumbs up for the makers of Tmpgenc DVD author and ofcource DVDLAB what is just awesome when it comes to putting svcd on dvd
CYA,
DVDGEK
cutting a vob to edit the clip and later merge with original without re-enc
By Srivas in forum EditingReplies: 4Last Post: 25th Dec 2010, 02:37 -
Cutting VOB File without any quality loss? (ending credits)
By willhenderson in forum Newbie / General discussionsReplies: 10Last Post: 15th Oct 2008, 23:45 -
Is VobBlanker good for cutting parts off of VOb files???
By mabhz in forum EditingReplies: 5Last Post: 28th Jul 2008, 04:01 -
Cutting VOB files
By DELTAsnake in forum EditingReplies: 20Last Post: 6th Apr 2008, 17:23 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 09:52
