I recently downloaded an SVCD film and when I run it in Windows Media Player, I get this horrible green blotchy green that does my head in.
I have installed all the codecs you can imagine.
From xvid
nomic
slc
I even tried ffdshow, tmpengc and some others and still no luck.
I feel as if there is no more hope.......Can anyone please give me a solution so I can sit back relax and enjoy the film
Thank You
Results 1 to 28 of 28
It's probably an mpeg-2 file. try viewing it with a DVD software player such as windvd or powerdvd. or maybe divx5 or one of the xvid.
Don't knock on deaths door, ring the doorbell and run, death hates that! -
I have tried windvd and powerdvd and it still shows that stupid green screen and makes the hiccup noises.
Please helppppppppp :'( -
The problem is, that you, like you said, installed every possible codec! Your system is now confused and tries to decode with the wrong codec. You have to uninstall everything and then re-install, starting with the Xvid-codec, which is, sorry to say, very sensitive to the adding of other codecs and produces a horrible green screen when it has a conflict with other codecs. So, install that one first and try your movie. if it still won't work, add another codec, like mp2 or divx, and try again. When the movie can be played, stop installing, and try the different codecs you installed with some movies in that format.
Cheers,
Richard -
I will try that approach.
I will give a response if I still have probs.
Thanks a lot!!! -
I have been uninstalling and all that stuff and still no luck
Maybe there is no hope.
If anyone came across this prob Like I did and found a solution please holla -
I was having the same problem with a LOTR AVI, it worked before I just did a format and re-install of XP, I then dl'd nimo, avi-codec, divx5, and another one and suddenly my movie was green????
So I did what that above person suggested, removed thme all one at a time, trued, and finally after nimo being the last one.. it worked
I hope all my other vids still work
Good luck -
Have you tried using gspot from the tools menu to determine EXACTLY what codec/codecs you need
No I have not!
Where can I get it cause I have not seen it in Tools on this site.
Gspot
...but your first post says:... GSpot is only good for AVI's, but on the other hand:I recently downloaded an SVCD film
If it's really SVCD, then it's mpeg2, and the player for those are DVD players, like PowerDVD, and they come with their own codecs. It has nothing to do with XviD, ffdshow or anything else.
/Mats -
So are you saying I shoud unistall everything else and use power dvd or windvd.
Because power and win still give me the green screen and sometimes even crashes.
Holla pls -
Never found that any AVI codecs would interfere with mpeg1/2 codecs. They seem to be in no way related, at least not on my system - been having all sorts of problems with AVI (being stupid/gullible enough to install Nimo 8...) on and off, but mpeg decoding has never failed me.
Sounds like the mpeg is really corrupt and beyond rescue.
/Mats -
I had a SVCD and used ISOBUSTER to extract the MPG file. I then used TMPGEnc to Multplex it from MPEG2 to MPEG1 as explained in the guide for the VCD Header trick. When I played the converted file on my computer I had a green screen. Is this because of a problem with a CODEC not being installed? Will it play correctly on a DVD player? Can I cause any damage to my DVD player if I play a VCD using the non-standard VCD 2.0 format?
Hello I just recently installed the Elisoft codec multi pack and still no fuckin luck!
Whats my problem pleassseeeeeeeeee }(
Another person said they got this player called MD2 or somthing like that and it removed the green screen!
If any one who are gurus at this please email me asap killa_composa@hotmail.com
Thank You -
Use fourCC changer and then post back to say 'bejesus, it worked'
http://www.divx-digest.com/software/avifourcc.html
copy and paste your file to the desktop, import it into the 4CCchanger and then type 'divx' into the bottom pane and away you go -
First when you got the source file are you sure that it was mpg format? It wasn't a bin, iso or something like that?
How do you know that the file is in SVCD format? What is the resolution of the file?
Do you have Nimo Codec Pack Installed? -
Its actually mpeg but svcd quality!
I dont have nimo installed but Elisofts Codec pack is!
Any suggestions
Thanks -
Purely from the HD!
Do you think that could be a solution?
And If So how can I burn a file thats big like 768 and my CDrw is 700mb
If so please refer to me a link where I can read up on how to do it please
Thank You! -
I'm pretty sure it will be OK when burned, It's worth a try.
Whoever encoded to Mpeg2 might have done so from an XviD, I can't be very specific I'm afraid except I know that 'green' is an issue with XviD!.
Nero will overburn your file as long as the options are set up properly.
G' luck -
I am proud to say that I have gotten rid of the green screen by simply burning the cue file using nero
Running it straight from the hard drive newbies may cause you problems.
I want to thank all you guys for providing help and tips to me when I was going through all these problems.
I now watch clean quality svcds
Nza -
go here and download the filter for xvid and get rid of the green. Then you can play the movies from your drive without any problem.
http://www.divx-digest.com/software/tsunami_pack.html
Avidemux Green Screen
By FrozenInferno in forum Video ConversionReplies: 4Last Post: 2nd Apr 2011, 23:31 -
Green Screen Advice
By HoosierGuy in forum Newbie / General discussionsReplies: 19Last Post: 8th Mar 2011, 09:53 -
Underwater Green Screen
By kccannon in forum EditingReplies: 6Last Post: 21st May 2009, 20:35 -
Screen turns green
By boysha in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 14:46 -
green screen when capturing
By HDMI in forum Capturing and VCRReplies: 1Last Post: 30th Jul 2007, 12:37
