Is there a special trick to frameserving to CCE SP 264? I can use VD and AVIsynth to frameserve to CCE Basic but the .AVS and .VDR are not valid extensions in CCE SP. When i try all files i get an open error. I'm using VD 1.5 and Avisynth 2.0.8.
You could create an AVI from the AVS or VDR using VFAPIConv.
I use the same versions of CCE, VD and AVS as you and it works fine.
You can download the software here
Note: I do find that AVISynth scripts work better if you insert a
before any resizing - I found multipass encodes hanging quite frequently without it.Code:converttoyuy2()
Mr Grumpy; Thanks for the nfo, nice to know it can be done. I had already D/Led VFAPIConv 1.05 but it seems to like only TMPG project files. So how do you get VFAPIConv to recognize the .AVS.
If you're using avisynth 2.5, you MUST add a ConvertToYUY2 - CCE cannot handle YV12, which is what AVISynth normally uses......
I've found that CCE 2.64.01.07 under Windows XP accepts AVS files with no problem.
However, you can also use the freeware ffvfw to wrap an AVS file as an AVI file that CCE will normally accept - ffvfw is probably available through the Tools link at the left, or over at doom9.net. -
Erm, dunno - mine just does. When I click on the Add Job button, the dialog defaults to AVS, D2V, VDR and TPROriginally Posted by bf6239
I'm running v1.04Beta of VFAPI
Thanks everyone for your help. I found an AVI wrapper, LINK2, on Doom9
that appears to work. It is $15 shareware.
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 03:15 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 17:22 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 12:41 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
