Hi, I have been using instant copy for the past couple of months and I just got the highly rated verbatim data life plus dvd+r's and I came across a new problem on two different movies, IC would say it burned successfully but by looking at the disk I could tell it didn't burn out to the edge, and the movie stalls about 3/4 of the way through, has anyone had the same problem or know what I should do? My method is:
dvd decrypter
Instant Copy (V 7.01)
with a sony DRU-120a with updated firmware 1.51
I've burned both movies successfully on a Phillips dvd+rw disc so I think its the media but I seem to hear only good things about this media.
thanks
try to update to 7.02...
http://www.mrbass.org/instantcopy/
older version would only burn 3 or so gigs
w/o reg hacks, a little better now, most say
try to overburn to 4.5-4.6.... -
I had the same problem. Best is to use PDI2ISO and burn the ISO with DVD Decrypter. No more coasters since I switched to that method...
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 19:04 -
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 14th Feb 2011, 00:05 -
Trimming AVI in virtualdub,direct strem copy ignores my start and end point
By Rudyard in forum EditingReplies: 4Last Post: 4th Oct 2010, 20:11 -
cant copy Pirates of the Caribbean 3 World End
By ricksmitty in forum DVD RippingReplies: 4Last Post: 8th Jan 2008, 18:43 -
burning troubles on the back end
By beck59 in forum Authoring (DVD)Replies: 1Last Post: 25th Dec 2007, 00:11
