I have tried using tmpgenc to convert avi to mpg and burn with nero to play in a stand alond dvd player. I have tried it a few different ways and still won't play ... my dvd players do support vcd and svcd so i am at a loss . Will someone give me some one on one how to do this i will even show you a text that i went by one of the times and it still doesn't work . I also used info from the vcdhelp maybe i am doing something wrong i don't know. thank you
Are you sure your DVD player can read CDR discs, or the specific media that you are using. Try making an audio CD and seeing if your DVD player can play that?
You can also d/load the demos (fairly small), burn and try to play them as a test. Click on VCD,SVCD, x(S)VCD to the left for the demo clips.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
VCD
By dodd22 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 17:01 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
VCD
By rocketboy in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 15:06 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
