I'm quite used to burning movies with VCD Easy & Nero, but I've just downloaded a VCD movie & when extracted from its RAR files I get a folder with:
*.CCD file - 1K
*.IMG file - 817,045 kb
*.SUB file - 33.349 kb
I havent come across these files before & at first glance I can't find any way to burn these to a disc using the above 2 applications.
The answer is probably dead simple & I'll kick myself when it's explained but how do I get the movie onto disc please.
TIA
PAUL
In Nero, if you might be able to do it with the "File->Burn Image" function.
If you select "All files" option, then select your .DAT file, it asks you for some information about CD type, block size, etc. I don't know what these should be (although someone else here should).
The only other thing I can think of is to use CDMage (downloadable from here to open the .CCD, then you can 'Save as' to create .BIN/.CUE files which Nero should be able to use. -
Hi,
Thanks a lot!
Clone CD was the one I needed.
Just burned the disk & its fine.
Once again thanks.
I think we can close this thread now.
Paul
I can't burn some files what can i do?
By rko2164 in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2010, 20:38 -
how can i burn these 2 files to a dvd?
By uglijimus in forum Authoring (DVD)Replies: 4Last Post: 24th Nov 2008, 16:15 -
Can't burn TS_Video files
By OzarkBaby in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2008, 20:23 -
Best Way to Burn HD Xvid files to DVD?
By expat in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 11:51 -
How do I burn .rar files and other
By cinemanetwork20 in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2007, 10:48
