Help I ripped an isolated score from my DVD but I would like to convert it to wav or what ever how do I go about doing this. I don't want to make a vcd I want an audio cd.
Thanks I've tried thousands of programs but no luck
Is the audio ac3-then the prgram ac3dec is for you
it coverts to wave format. You can prob find it at http://www.doom9.org
I'd use DVD2AVI and bung your VOB(s) in and then use ultra-high quality setting for Dolby Digital>WAV.
Alternatively, you could use the program suggested above by extracting the ac3 file out on the VOB. -
I tried but I don't get the wav files your supposed to,
Could you give me a full setp by step thanks -
use vob2audio. it will extract a perfect uncompressed wav file. then you could amplify it in a progy like cool edit (200% is my setting). you can even export the wav thru cool edit and make it in mp3 format.
http://www.doom9.org/Soft21/Files/Audio/v2a.zip
ps. just make sure you read the INFO file (txt file) from your extracted vobs to choose the correct ac3 audio.
GOOD LUCK vrmtlr.
later bater. deltaboy -
I was using Smart ripper to extract the files into ac3 but When I play it I only get half the sound not the whole thing And the movie is Hollow man I only get the first 50 sminutes of it where is the other parts?
Looking For Football Score Bezel That can Be Added To A Video
By JohnnyGalaga in forum EditingReplies: 1Last Post: 24th Sep 2011, 16:28 -
Does Anybody Need a Soundtrack or Score?
By TheIcarusDescent in forum AudioReplies: 59Last Post: 21st Jun 2011, 01:05 -
How to add score board.
By LoMayok in forum EditingReplies: 2Last Post: 12th Nov 2008, 16:59 -
Reduce volume of music score ?
By CompVid in forum AudioReplies: 2Last Post: 1st Jun 2008, 13:01 -
removing music score without affecting dialog...
By rprevatt in forum EditingReplies: 1Last Post: 2nd Nov 2007, 11:57
