Hi there guys can anyone tell me why i cant see the dvd video option in this proggy, using a sony 500ax burner. File>new job has only videocd option. As i remember dvd video option was only there on the first time i started the proggy
thanks
Results 1 to 9 of 9
Hi Mrsash
If the Max version is like my Dx, there isn't a dvd option, and there isn't anything in the help files.
I simply create a data disc and copy the relevant Video_ts & Audio_ts folders into the disc, (there is an option in the setup menus to recognise Video_ts as dvd, which should be turned on I think). Change the setting to close disc on completion, then record..et voila.
Simple as that, but no mention of dvd recording in the program itself.
L8r.
RecordNow DX also
What exactly do you have to do to make the VIDEO_TS and AUDIO_TS folders? I have been unsing DVDshrink which outputs vobs, and other stuff. Do you have to reconvert the stuff into a diff format, or do you just slap certain files in a folder you name VIDEO_TS and others in a file you name AUDIO_TS??
Thanks -
"or do you just slap certain files in a folder you name VIDEO_TS and others in a file you name AUDIO_TS??"
Yes just create a VIDEO_TS folder and put the files in it. You really don't need any AUDIO_TS folder. -
Just to let you know.... there is some option which will enable somkind of DVD checking.....
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Hi,
I ran into similar problems couple of weeks ago. Actually it's very easy to burn a DVD with Recordnow IF YOU KNOW HOW.
1/ Put all DVDShrink output files in a folder VIDEO_TS
2/ Start Recordnow>Data disc /close wizard/>Select DATA from Menu>Add the folder VIDEO_TS /the folder not the files!/>Select New Volume>Change Volume Label /The Matrix for ex.-opt./>Burn
I hope I didn't miss anything. If yes correct me please.
Burne several Verbatim +Rs 2.4X this way all worked fine even on PS2.
Enjoy! -
Well i wanted to make a dvd from the something.mpg file i had created from studio 8, since S8 completely failed burning it on dvd. Now i rerendered the entire mpg as dvd in S8 and it worked. but two probs
how can i burn something.mpg file as dvd in recordnow max? When i first installed it i saw dvd video option and it disappered next time and only showed video cd in its place,figure that one.
The second time rendered the footage on to dvd, i can only fastforward 2x any faster and it does not work, in fact it irractically plays any part of the mpg
thanks for your help guys -
You have to author it first. I used SDV 7 for capturing, editing and output to AVI. I then use TMPENc for encoding to MPEG-2 (Default Settings for DVD). Then I author using either Dazzle DVD Complete or ULEAD DVD Movie Factory. Both these authoring programs create VIDEO_TS and AUDIO_TS folders. Only the VIDEO_TS folder contains any files. I then burn the VIDEO_TS and AUDIO_TS folders to a DVD in RecordNow using the Create Data Disc Option. I've made several home movies this way that play just fine in my Standalone DVD player.Originally Posted by Mrsash
You should be able to find answer for "how to prepare VIDEO_TS" in Studio 8 in thi post...
Pinnacle Studio 8 and DV home video editingPinnacle Studio 8 and DV home video editing (ver.9 already home)
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 14:53 -
Max Mp4 player
By drrino in forum Portable VideoReplies: 1Last Post: 28th Feb 2012, 01:04 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
MPEG-2 max bitrate
By Sjakko in forum EditingReplies: 16Last Post: 12th Jun 2009, 12:29 -
Max I Frames on DVDs
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2008, 19:19
