  1. Is there a special procedure one needs to follow to burn a VIDEO_TS folder to the root of a DVD?
    Maybe a real Noob question - but as you need to to specially select the DVD option in Toast - was wondering if a similiar extra step was required with Disk Copy
    tia
  2. I had the same question in another thread. If you create an AUDIO_TS folder (just an empty folder) and put it with your VIDEO_TS folder in a new folder and then use MissingMediaBurner (check Version Tracker) to create an .iso disc image, you can then use Disc Copy to burn your DVD.
    It has worked for me on three back-ups so far.
    tia
  3. Originally Posted by Pretzel
    tia
    Only thing you need to do is to insert the blank DVD in you drive and wait for it to pop up on the desktop, name it and drag the VIDEO_TS folder to the disk and add another folder called AUDIO_TS to the disk. this works fine for me and have so far not had any problems with the disks on my home DVD player.
