I have alot of VHS tapes of family events I want to put on cd and make a vcd. Can someone tell me what type of sound or video card do I need to transfer my vhs tapes to my computer?
Depends entirely on how you want to capture them.
If you have a Canopus ADVC or other firewire capture product then you only need a firewire port on your PC.
Therwise, you're goung to be capturing using a video/capture card, comparisons of which are found here:
https://www.videohelp.com/capturecards
Once you've done that, you may want to read:
https://www.videohelp.com/forum/viewtopic.php?p=511227#511227
It's for VHS to DVD but the principle is the same.
Regards,
Rob
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 00:58 -
Need also expert advice about video and sound files!!
By vantechmag in forum EditingReplies: 8Last Post: 14th May 2009, 10:48
