OK, im trying to use TMPGEnc to create MPEG 2 files in video size 704x480. No matter what type of input video i use, i ALWAYS get this error message somewhere along the line. It is always at a RANDOM point during encoding, NEVER the same point twice.
Read Error Occured At Address 00499F87 Of Module 'TMPGEnc.exe' With 00000004
How do i go about fixing this up!????
At first it happened with TMPGEnc Plus 2.510, so i thought it may be a bug of the new version, so i got my hands on a copy of TMGPEnc Plus 2.57, but it still happens. Whats going on here, and how do i fix it up, its a very frustrating problem![]()
most of the time this occures is because you dont have the right codecs ive found out, uninstall and reinstall your codecs, make sure that when you play a vid that you can advance it, that means you have the right codec. theres also a guide inthis site that shows you how to set your environmantal settings intmpgenc, but i cant seem to find it right now, ill keep looking and post it when i find it
dont overclock your FSB.. sounds heat related .
are you running -any- other software on the computer?
Whenever i do encodes i unplug from the network, close my firewall, virus killer, protein folding, jukebox detector, motherboard monitor and any other crap i have running.
I had less problems with TMPGenc following those steps, though these days i never use it anymore!
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
Constant resolution in GK
By eliqush in forum EditingReplies: 0Last Post: 5th Aug 2009, 10:28 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
