I wanted to take different scenes from dvd's that I have backed up on my hard drive and burn them on one dvd. Is there any way I can do this. Any help would be greatly appreciated.
perhaps I should have posted this in the newbie section because I don't know how to do anything you just described. Is there a guide on this site or any other that might take someone like myself step by step through a process like this?
Originally Posted by SoCalMK
<<<<< did you read any of the guides over there ? -
I have searched and haven't found one specific to this situation. I'm assuming that it could be that I just don't know what I am looking for. If you know of a specific guide, could you please put up a link for it. Thank you.
VEGAS VIDEO 4.0 will accept the AC3 streams from a DVD?
Cool.....Or do you hav'ta convert the .VOB's on your hard drive using
a DEMUXING TOOL, that will also convert the AC3 to an editable audio stream type..If so what demuxing tool is good (does VOBEDIT handle ac3 conversion?)
Could you then use dvda (ARCHITECT) to make a big movie with each segment being a CHAPTER?
(THAT IS NOT HAVING TO USE SEPERATE BUTTONS like with DVDit?)
Combining VOB files from different sources to create a new compilation
By bluesmanuk in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2010, 14:24 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
DVD compilation.
By Benhermies in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2008, 11:46 -
Making compilation DVD?
By chronic777 in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 12:19 -
trying to create a compilation DVD and getting nowhere
By JasonWatkins in forum LinuxReplies: 2Last Post: 26th Oct 2007, 21:06
