Is there ANY difference in encoding quality between,
CCE 2.50
CCE Basic
CCE 2.67
Was planning on buying CCE Basic....
Hopefully all CCE's use the same encoding engines??
Also,
Forgot to ask what are the specific advantages over the SP version against the Lite?
Hopefully they are more similar than different in features! -
there is one major difference between the lite and the full and that is vbr availability. The lite comes only with cbr. You really want vbr availabilitybecause you will not get the size vs quality with cbr.
I know the lite only has the cbr option...as for the basic which is there newest program, I couldn't tell you the options available.
If you go to Custom Technology's (CCE manufacturer) website they have a complete breakdown of all the features that each version has compared to others. The lite version is pretty much useless now, because the Basic version does much more for much less.
As far as quality differences, not related to actual restrictions placed on any given version, there are little. Versions 2.6x implemented updated encoding algorithms, but I cannot see any perceptible differences. I think the Basic version may also have these optimizations, but I'm not sure. These versions do offer many new filters which could allow you to achieve better quality overall, but I prefer to do my filtering through other software and I don't particularly see CCE's filters offering anything better than what is available elsewhere.
In my opinion, there are very little quality differences between 2.5 and 2.6x. The Basic package is more limited in its features, but for the price it is still an excellent deal.
quality difference hi8 vs digital8 tapes
By avmaster in forum Newbie / General discussionsReplies: 4Last Post: 23rd Apr 2012, 15:20 -
Quality difference with MKV?
By pixaren in forum Software PlayingReplies: 4Last Post: 21st Jun 2011, 12:12 -
quality difference for multiple reincodes
By resloan in forum Newbie / General discussionsReplies: 14Last Post: 30th Mar 2010, 22:31 -
Will there be a difference in output quality?
By ingeborgdot in forum EditingReplies: 55Last Post: 21st Sep 2008, 19:41 -
What's the difference in quality between SP & LP modes in MiniDV??
By navi310 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jun 2007, 12:09
