what is the best and is easy to use?i want to make one like a dvd menu with chapters and other stuff and is there away to make your vcd play when you put it iin cause i have to press play?
thanks
Do a search on autoplay for more info, but bottom line is that most DVD players don't support autoplay x(S)VCDs.
As for making Menus. You asked two different questions. Which is the best? and which is easiest?
Your best bet is TSCV (www.ttool.org) d/load the newest ver and the newest VCDImager (both on site) and read the on line guides.
I've used TSCV to make a motion menu to each chapter on my disc, still menus, multi-level menus (up to 9 deep), place seamless chapters, intro mpeg, etc.
HOWEVER, the program is still beta. If all you want is a menu and chapters everything will work fine. Some people have trouble with the enbedded media player thou (for making stills and motion menus). If you have this problem read the forumn there for help or try loading a VFAPI avi just to make your menu.
What Program was used to create these menus?
By BIGD22 in forum Authoring (DVD)Replies: 14Last Post: 21st Nov 2011, 18:43 -
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 23:48 -
How do you make menus for dvds....
By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 12:33 -
How will I make an AVCD with menus?
By zeldAIS in forum Newbie / General discussionsReplies: 19Last Post: 4th Aug 2007, 15:12 -
Looking for a presentations program to make dvd menus
By faramith in forum ComputerReplies: 0Last Post: 1st Jul 2007, 10:00
