  1. when i use osex and then sizzle to get an image for smaller movies i use disckcopy on my mac and it works on my dvd player. I am having problems with toast, i have version 5.1.3. I have my VIDEO_TS folder i made from dvd2one using the disckcopy method, and I make a blank AUDIO_TS folder. I through both of them into toast and record. My dvd player cant read the burnt disk. My dvd player can, wassup? help.
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    Its the I THROW BOTH OF THEM INTO TOAST AND RECORD where you are messing up I think
    Do this.
    Make a new folder on your HD. Name it using the DVD name like this (DVD_NAME) example SERVING_SARAH or THE_ONE
    Drag your VIDEO_TS folder to this newly named folder.
    Now open that folder and you should have just a VIDEO_TS folder. Add a new folder and call it AUDIO_TS so that you now have TWO folders.
    It should look like this
    DVD_NAME
    -----AUDIO_TS
    -----VIDEO_TS
    ---------all those video_ts files
    NOW, drag the DVD_NAME fodler to toast under the DVD option.
    NOTE HOW TOAST NAMES THE DVD THE SAME AS YOUR FODLER called DVD_NAME!
    Thats very important. Simply dragging both AUDIO_TS and VIDEO_TS folders to toast will make a dvd named AUDIO_TS with a subfolder of VIDEO_TS
    Thats not how to do it!
    Check my post on HOW TO PROPERLY BURN DVD2ONE DVD WITH TOAST
    for more info
  3. thanks, works good
  4. Member galactica's Avatar
    Jan 2003
    Excellent!
    its trickey cause people dont understand (well most dont) that toast assumes the folder you are dragging into it is to be the disk name! unless you have already added a disk and named it with toast.
    Thats why I have the foolproof method posted in this forum.
    I think ill bump it up so everyone can see it easily still.
