  1. i'm lost, in every dvd that i make the audio is out of sync with the movie.
    it used to work just fine, but about 2 months ago every movie that i made has the audio problem, the audio is about 1 or 2 seconds off with the movie.
    i first extract the audio from the movie using virtualdub 1.4.9 .
    then i use vdub again to add subs to the movie using the framesering option.
    then i use tmpgenc (2.510.49.157-Plus), i load the avi + sound and the framserver dummy file.
    but when tmpgenc is done and i watch the result the audio is off.
    but when i watch the original avi with the sound extracted with vdub using micro dvd player then its perfect
    (out of 10 movies, 9 of them the audio is wrong.)
    i have tried everything that i could think of ,i used the MainConcept encoder but that gives the same results
    does anybody have an idea
    thx
  2. had the same problem......... switched 2 DVD2one and all my problems are solved and it takes about 5 hours less time to backup my favorite DVD's.
    Worth every penny!
    Thursday
