LOTR extended backup.
I decrypt dvd 1&2, movie files only, rename vob files 001 to 013 and place them in a working folder.
Then I use Vobedit to join these files together; I am left with vob 01 to 13.
I use ifoedit to create ifo, then change all audio and subtitles to English language. I then save. I then get vts sectors and resave.
When I play the dvd files in powerdvd its okay, but will only play upto 2hrs45mins? (of the3 1/2 hr movie)
I actually created a working backup using this method, but the subs were not right so I deleted it!
Can you see any reason why this should not work? Have you come across anything like this before?
Like I said the green subs were my main problem, but now I can't get back to where I was in the first place!
Thanx for helping.![]()
I used dvdo2one to process the dvd, (12GB worth), and the resulting 3.25GB file, (even though I set it to 4.4GB!), seems to play okay.
PowerDVD must accept correct DVD sized movies only, (9.4GB max)! I never considered this.
L8r.
WOW, you like having a 25% quality level?
65% is minimum w/ so-so quality.....
DVDSubEdit... Everything Is Wrong!!!
By Typhoon859 in forum SubtitleReplies: 18Last Post: 5th May 2009, 09:08 -
what wrong with this code?
By emogal in forum ProgrammingReplies: 3Last Post: 11th Jan 2009, 05:12 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 10:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 19:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 05:11
