Couldn't find an answer in the search...
When in the Navigation Simulator of DVD Maestro, I can't seem to get the ROOT menu button to point to my main title screen. Which is annoying because the same problem exists on my DVD remote. The First play and Title menus work fine, I just can't get the ROOT to do anything. Since it doesn't show up anywhere in Connections I am a bit confused on how to assign it?
Any info would be much appreciated, thanks.
rhuala
DVD Maestro v2.9
on your time line in your FIRST chaper on the video time line - > right click and assign root menu location (ussually your chaper location menu or master menu) ,, maestro will automaticaly do this as the same location for all other chapters unless you manually change one ..
its in the manual somewhere .. -
Sorry I just can't find it, I'm looking at the time line in a movie and right clicking everwhere and see nothing about the root menu.
Edit Marker
Rename Marker
Set PlayCursor
Set Punch Point
Set End Action ->
Set Menu Key ->
Delete Marker
Import Chapter List ...
Properties
Properties shows othing about root menu
You have three areas above a movie: Wall clock, Chapter time line and movie time line. I have manually set up chapters and right clicking on them reveals nothing about root menu. I must be blind but I've just about right clicked every sqaure mm of my screen and can't see anything about assigning root menu. Would you please clarify a little. Thanks.
rhuala -
ok, I see it now. Got it working, boy is that every convoluted. Thanks again...
rhuala -
BJ_M You're the man!!!
I've been racking my brain on every aspect of menus in DVDMaestro, and everytime I search the forum for help, it's a post from you that saves my ass!
Thanks for taking the time!
how do i create a multi page root menu.
By visualhippocracy in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2011, 14:02 -
Philipps DVP3360 DVD player displays STOP / ROOT
By offytuf in forum Newbie / General discussionsReplies: 0Last Post: 22nd Mar 2011, 16:06 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
Setting New Root Menu in DLP...
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 23rd Jan 2008, 03:29 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23
