Gang I am not sure how to go about this..... I have a movie file that came to me in a tar format, so I opened the compressed format and I ended up with a cue/bin format.... I know I can burn it to CD-R (but it won't play in my DVD players) so I want to burn it via my dvd burner.... Is there a way to go about this???? It appears to me that if I can only save the bin file to my harddrive then I should be able to burn; however I am not sure.... Also if you have a movie file in a dvd format then what software can you use to make a burn straight to dvd??????
Thanks........
So you have a movie stored in a cd image and want to get it on to DVD, right?
So, use google to find isobuster and use it to extract the mpeg files from the VCD or SVCD image. Once you have those, then look to the guides for help on converting/authoring to DVD compatible format.
