Gang I am not sure how to go about this..... I have a movie file that came to me in a tar format, so I opened the compressed format and I ended up with a cue/bin format.... I know I can burn it to CD-R (but it won't play in my DVD players) so I want to burn it via my dvd burner.... Is there a way to go about this???? It appears to me that if I can only save the bin file to my harddrive then I should be able to burn; however I am not sure.... Also if you have a movie file in a dvd format then what software can you use to make a burn straight to dvd??????
Thanks........
Answered in another forum. Please don't double post.
Also, a more informative subject line gets better results."Art is making something out of nothing and selling it." - Frank Zappa -
see the post above this that refers to "How to tell bin / cue format. there is an answer in there.
As to subject headers - if you try to state your problem in the header of your post you will get more response and it will be quicker.
Not a criticism but a suggestion from experience!
Tom
