hello to all i have this firewire card it was prinstalled in my computer how is this card can this card encode my movies to vcd and dvd and can anyone pls help me in finding the latest driver of this card
Texas Instruments OHCI Compliant IEEE 1394 Host Controller
chant chant chant gods name
I have that exact card. I bought it under the name SIIG at Fry's electronics. Mine works great for cuptureing DV. Maybe you can find drivers at the SIIG website http://www.siig.com/. Anyway the card has no encoding power or software. You need software like Ulead Video Studio or others to encode.
A FireWire card is just an interface for you to connect to your digital devices ( i.e. like a FireWire scanner and your miniDV cam ). See it like the USB port. As for drivers, I believe it can use WinXP standard drivers ( if you run WinXP ). As mentioned by DVD1234, it has got nothing to do when you encode. You capture your video via the FireWire card and encode it separately.Originally Posted by hello there
Win XP recognized my card and already had the basic drivers. Not sure about Win 2000 and Win 98 probaly doesn't have the drivers.
I may be mistaken but I am pretty sure the driver is the same one from windows 98 thru XP. Search as you may, they don't exist...Been there , done this...LOL
thank u everybody for ur answers but just one more question is ther any software wich can directly encode to vcd or dvd through firewire as we all can do through svideo and usb pls do answer thanking u all hello
chant chant chant gods name -
I use Ulead Video Studio 7 to encode from DV directly to VCD format. I can also edit the video and add effects if needed. It also has SVCD. There is other software also availible. Don't get Dazzle.
My IEEE 1394 cable can't be detected
By edhani in forum Capturing and VCRReplies: 1Last Post: 14th Jul 2011, 08:19 -
IEEE 1394 card
By beavereater in forum ComputerReplies: 1Last Post: 21st Jun 2011, 05:28 -
IEEE 1394/MS DV ERROR
By sampatman in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 11:54 -
Problem capturing using IEEE 1394 and camcorder
By Shabaman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 22nd Aug 2008, 08:04 -
is the IEEE 1394 Adapter port necessary...
By roochie in forum MediaReplies: 15Last Post: 15th May 2007, 20:03
