Results 1 to 10 of 10
  1. Hi,
    I'm considering of giving some 4X -R media a try so i would like to ask those who already have some experience with these which -R media DEFINATELY burns at 4X with Sony DRU500A/X and which burning program is recommended ?
    Thank you!
  2. i have had success with datawrite red 4x with the sony dru500a
  3. Thanks for your reply,
    And what about those Riteks /G04/ guys?
  4. Originally Posted by Gregg
    The Riteks seem to work fine as long as you have the original firmware version that's my experience so far.
  5. The Princo 4x for rima.com works ok
  6. And another question, which firmware version are you using to burn on those dvd-r?
  7. 2.0e
    Burned 4GB MPG file with Dazzle DVD Complete or Sonic DVD Arch 14.00Mins
    Aug 2001
    Finland
    Which firmware? I tested two discs: fw 1.0f started 4x but soon dropped to 2x, fw 2.0f didn't eve try to burn 4x but started 2x from the start
  9. I have burned Ritek, Verbatim, and TDK 4x media and all woked fine.
