  1. Is it ok to run other programs, such as safari, and ichat, while the computer is running DVD2one or Re-encoding mp2 lets say? I know it takes proc time but is that all it affects? Thanks
    Mel
  2. No prolem. You can do whatever you want during the time DVD2One is working. since OS X is UNIX every app has its own memory and wont be affected by you running other apps. Its only going to take a while longer to process the DVD.
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    And it does add quite a bit of time to the process if you are doing other things, but it does not hurt the encoding in anyway.
  4. I could swear that APACK crashes when I do other things in OSX. Can't be positive but if I leave the computer alone (no browser) it never crashes.
  5. Originally Posted by lawgiver
    I have run up to 5 other programs while encoding on a Quicksilver 867. Just extends the time for encoding, does not affect the process. 8)
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I've run APack hundreds of times with other applications running and it's never crashed.
