I have a number of Xvids i am trying to convert to VCD.
When I try and extract the audio with Virtual Dub I get an error saying "no audio decompresor could be found to decompress the audio".
These are Ac3 audio and they play fine on the PC.
If I convert the video using Mainconcept (which allows dix/xvid to be encoded without extracting the audio) the audio is out of synch with the video.
I also tried goldwave which wouldn't open them.
Fozzee
Virtual dub
Save Wav - direct stream copy audio.ac3
Explorer remove .wav extension
Use headac3he open file, click convert.
Encode with tmpgenc
Let me know how it goes. -
This is what it says in gspot "ac3 (0x2000) "Dolby Laboratories, Inc"
Fozzee -
Does Gspot say that the AC3 codec is installed? If it is, then Goldwave should be able to create a wav file, it always does for me. If it isn't, then get the codec from the Tools section.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by hardcoreruss
SPOT ON !!! It worked. please explain further why you need to do this?
Cheers
Fozzee -
It does say the AC3 codec is installed. But Goldwave doesn't open it . It crashes.Originally Posted by ZippyP.
I use Goldwave to extract to wav on most of these files but there a few that won't open.
Fozzee -
if your having problems extracting you may want to try avi2wav http://www.divx-digest.com/software/avi2wav.html
then do what hardcoreruss said
Opening .ac3 audio files in Sony Vegas?
By Thunderhead2772 in forum EditingReplies: 1Last Post: 18th Jul 2010, 21:55 -
Mov file with mono audio plays silently: fixed by opening Super
By aslaksen in forum Video ConversionReplies: 0Last Post: 7th May 2010, 20:35 -
Audio missing when opening an Avisynth script in WMP & VirtualDubMOD
By aln688 in forum Video ConversionReplies: 3Last Post: 2nd Apr 2010, 06:09 -
Opening Video with MP3 audio in VirtualDub!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 11:18 -
Can't get Xvids to work in VDub
By clos in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 12:47
