Want to play around with the look of PowerDVD and you are not using the standard skin.
Open the appropriate Skin folder in Cyberlink\PowerDVD\Skins
The image base.bmp lets you adjust the look of the player and Logoscreen.bmp lets you change the look of the unloaded playing window
Go from there with the other bmp if you wish.
Just save the changes and see what happens.
Make a copy of the original of course.
Results 1 to 1 of 1
PowerDVD 7.3 and new BDRebuilder
By dharper40 in forum Blu-ray RippingReplies: 4Last Post: 7th Sep 2011, 08:23 -
PowerDVD
By BobbyScot in forum Software PlayingReplies: 1Last Post: 28th Aug 2009, 13:38 -
PowerDVD Shortcuts
By ocgw in forum Media Center PC / MediaCentersReplies: 0Last Post: 29th May 2009, 12:22 -
can't see anything on powerdvd
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 12:18 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54
